Дополнение MegaD devices
Владелец задачи: SergeJey, Минск - Беларусь
Поддержка устройств MegaD (http://ab-log.ru)
15.05.2021
Update megaddevices_search.inc.php
(SergeJey)
Support of quick navigation to linked object/property
https://github.com/sergejey/majordomo-megad/commit...
14.08.2020
Config fixes
(SergeJey)
Config fixes
Fixes related to inner config section
14.08.2020
Port delete fix
(SergeJey)
Port delete fix
Port delete fix
06.07.2020
Update megad.class.php
(SergeJey)
request processing fix
05.07.2020
Added support of MegaD-16I-XT
(SergeJey)
27.06.2020
Minor fixes
(SergeJey)
Minor fixes
01.04.2020
Update megad-cfg.php
(SergeJey)
15.01.2020
(SergeJey)
Minor config fix
13.12.2019
(SergeJey)
12.12.2019
Update megad.php
(SergeJey)
Update megad.php
27.11.2019
Updates
(SergeJey)
Updates
Обсуждение (1) (0)
23.09.2019
Update readvalues.inc.php
(SergeJey)
Minor fix
17.09.2019
Merge pull request #11 from directman66/master
(SergeJey)
Добавлены остальные файлы.
16.09.2019
Merge pull request #10 from directman66/patch-1
(SergeJey)
12.09.2019
Update megad.php
(SergeJey)
Update megad.php
Minor fix
21.08.2019
Reverse mode for IN/OUT
(SergeJey)
21.07.2019
Debug log update
(SergeJey)
Debug log update
Now requests to devices getting saved to the log when log is turned on.
19.07.2019
Device config update
(SergeJey)
Help added
19.07.2019
Merge pull request #8 from directman66/master
(SergeJey)
Добавлено управление устройством через web из админки модуля
18.07.2019
Merge pull request #7 from directman66/master
(SergeJey)
Add icon
19.04.2019
(SergeJey)
ReadValues after sending command removed.
26.03.2019
(SergeJey)
Removed unnecessary update operation
15.03.2019
Fixes
(SergeJey)
Fixes
10.02.2019
Update
(SergeJey)
Update
09.02.2019
Update megaddevices_edit_property.html
(SergeJey)
Device preview support added
01.02.2019
Negative values fix
(SergeJey)
Negative values fix
Fixing reading negative values for temperature/humidity
31.01.2019
Updates
(SergeJey)
Updates
Обсуждение (2) (2)
28.01.2019
Updates
(SergeJey)
Updates
28.01.2019
Merge pull request #4 from sergejey/alpha
(SergeJey)
Alpha
28.01.2019
Merge pull request #3 from sergejey/alpha
(SergeJey)
Alpha
(14)
Подписаться на обновления (22)
chainik 100.00 RUB
beavisgood 500.00 RUB
znachok88 500.00 RUB
Не распознаётся конфигурация порта NC +13
Дополнение не умеет корректно работать с расширителями MegaD MCP23017. +11
Произвольное включение света при рестарте контроллера Ab-Log +5
Модуль не обрабатывает событие long_press +5
Отображение ненужных данных +5
1wire устройства шиной не читаются. +4
После обновления модуль перестал обрабатывать изменения свойства привязанного объекта +4
Обновление портов +3
Добавьте пожалуйста поддержку MegaD-2W +3
Добавить обработку входящих СМС +3
Перестали работать физические кнопки (обновление 27.11.2019) +3
Датчик температуры микросхемы Mega328 +2
Не корректно обрабатываются сценарии по умолчанию с знаком | в тексте +2
Некорректная работа через инет. +1
Модуль не находит устройства при нажатии кнопки сканировать +1
Дополнение SQLMeter
Дополнение ATV Notifications
Дополнение Jitsi
Дополнение WebVars
Дополнение YaDevices
Дополнение USRIoT
Интеграция Google Home
Графические Планы
Дополнение MiLight
Дополнение Homekit
Дополнение VPNki
Дополнение SMTP Catcher
MajorDroid
Дополнение Wirenboard
Простые Устройства (ПУ)
Дополнение LivoloRemote
Интеграция Google Assistant
Дополнение Zont
Дополнение Insyte
Модуль Optimizer
Веб-сайт CONNECT
Дополнение Zipato
Дополнение Charts
Дополнение MQTT
Поддержка на форуме
YouTube-канал MajorDoMo
Модуль XiaomiHome
Модуль Ноолайт
